Помощ!Проблем с АСР на Алфа 147
  • #31
    ASR си е функция на ABS електрониката. Първата реакция на системата при сработване е да отнеме 'газта'. Ако това не е достатъчно, прилага спирачно усилие към някое колело (не съм сигурен дали всички го могат това). За да се 'включи' в случая ASR означава големи разлики в скоростите на колелата. Или пък грешни показания на датчиците. Или теоретично голяма разлика в размерите на гумите (т. е. да не са 4 еднакви).
    EBD също е функция на ABS, както и т. н. Hill Holder (ако го има).
    Lancia Kappa JTD '98 -
    • #32
      EBD системите май само след 2002-ра година се вгражда на 156. Или поне аз не намерих друга информация.
      • #33
        http://www.italiaspeed.com/new_model...47/safety.html
        The new Alfa 147 complements its high-performing brake system with an ABS antilock brake system as standard over the range complete with an EBD (Electronic Brake Distributor). The New Alfa 147 also assures absolute mastery of the car under all conditions, however extreme, due to its VDC (Vehicle Dynamic Control) and ASR (Anti Slip Regulation) systems. The VDC is Alfa Romeo's version of the ESP (Electronic Stability Program), a system that cuts in under extreme conditions when car stability is at risk and also helps the driver to control the car.
        The VDC is Alfa Romeo's version of the ESP (Electronic Stability Program), a system that cuts in under extreme conditions when car stability is at risk and also helps the driver to control the car. As befits a true Alfa, the VDC is a sporting device that allows outstanding roadholding. It allows the driver the full satisfaction of controlling the car as long as conditions are normal but cuts in just before things become critical. The VDC is permanently engaged.
        The ASR (Anti Slip Regulation) system, an integral part of the VDC, optimises traction at any speed with the aid of the brakes and engine control. The device computes degree of slip on the basis of wheel rpm calculated by the ABS sensors and activates two different control systems to restore grip: when an excessive power demand causes both drive wheels to slip (e.g. in the case of aquaplaning or when accelerating over an unsurfaced, snowy or icy road), it reduces engine torque by reducing the throttle opening angle and thus air flow; if only one wheel slips (e.g. the inside wheel following acceleration or dynamic load changes), this is automatically braked without the driver touching the brake pedal. The resulting effect is similar to that of a self-locking differential.
        Alfa Romeo 145 1.6 16V TSpark '98
        • #34
          Гумите са еднакви.Сега е с 4 зимни вече и е малко по-добре.Тука таме се включва и си мисля че е преден десен датчик на АБС прблема, щото при по рязък десен завой се вклч АСРа
          • #35
            Трябва да се види в движение в ABS какви скорости показват колелата.
            • #36
              Няма кво друго да е. Вдига се предницата на колата. Пуске се на скорост да си върти и се гледа на компютра какво показват датчиците.
              • #37
                как се включва
                светка светка и спира? или?
                • #38
                  колега oem,
                  ще те замоля да спреш да заливаш хората с технически и/или фактически невярна информация. няма да е първия път, в който пишеш пълни глупости и подвеждаш хората във форума.
                  Ex: 146ti, 146JTD, 147JTD, Lexus IS220D, Lexus IS200 Auto, Swift Sport, Subaru Legacy IV
                  Subaru Outback '09 & Alfa Romeo 156 2.4JTD
                  • #39
                    колега търтей,
                    ще те замоля да бъдеш по-конкертен и ясен, за да можеш колегите да се почерпят от информацията, която имаш и знаеш.
                    • #40
                      Първоначално публикувано от търтей Покажи съобщение
                      как се включва
                      еми как: светка, светка, светка................... и по некое време спре за секунда и пак светка, светка и тн...........
                      • #41
                        oem и търтей... издърпаха ли ви ушите пари ли
                        • #42
                          абе трябва да се види
                          щото както го описваш може и нищо да й няма на колата
                          • #43
                            Определено и има нещо.До сега не съм виждал кола да се джижи по енерция и като натиснеш педала на газта да се вклчючва ASR докато си е по енерция
                            • #44
                              Първоначално публикувано от vladu Покажи съобщение
                              колега oem,
                              Абе тая тема така се задръсти със свободни съчинения и откровена дезинформация, че мисля да я заключа.
                              Просто не подлежи на подреждане и разчистване баси
                              Volvo XC90 D5 '06
                              Alfa Romeo Spider 2.0 '90
                              Lancia Ypsilon 1.2 '00
                              ex Alfa Romeo 156 1.9 JTD SW Distinctive '02
                              ex Jeep Grand Cherokee 3.1 TD Limited '00
                              ex Alfa Romeo 166 2.4 JTD Q2 '99
                              • #45
                                ти па
                                забавна е
                                остави хората да си пишат глупостите
                                още не сме измъдрили наказание за писане на тъпотии
                                ма май му иде времето
